TPS92602-Q1: Calculating Loop Compensation
Part Number: TPS92602-Q1
I'm having difficulties to calculate the loop compensation for my application and also the provided example from the equations given in the datasheet.
Could you please provide a detailed calculation for Rcomp, Ccomp and C6 (equations (39) to (45) in datasheet), showing the values used and explained where do they come from?
Further, I don't see in equation (30) from where the 9mV for Vvout-ripple is taken. Could you please explain this?
More generally spoken, it would be really helpful, if there would be an Excel sheet for calculating an application circuit...
Thanks for any help in advance!
