I have a question about the device SN105125 with POK open drain output:
what's the status of the POK pin when the chip isn't powered or the supplied voltage is under the minimum operating voltage of SN105125.
So, I want to verify the POK will be held low during VCC ramp up or when the chip isn't powered?
Example:
SN105125 isn't powered and the POK pin is for example pulled-up with a resistor to a stable 3V3 voltage. Will POK be held low? Or will it be pulled-up?
