LM5141: The working principle of skip cycle mode and how does the secondary harmonics happened
Part Number: LM5141
Recently, I do some test about efficiency on LM5141, and I find my test result have a big difference from the data sheet. So I do some analysis on the base of SW waveform, and find that when the LM5141 work in skip cycle mode, and as the load current increase ,there will have a different change in the SW waveform as the attached file shows, I want to ask how does the controller change the number of switches. If it is according to the feedback of output voltage? Another question is why there will have a secondary harmonics phenomenon, how does this happened? The third question is why my test result have a big difference from our datasheet, if there have some problem on my test method? (The test report is attached). look forward to get some feedback . Thank you !LM5141 DCM efficiency analysis.docx
