TPS62624: About Figure 4. TPS6262x and TPS6262xEVM Efficiency
Guru 21045 points
Part Number: TPS62624
Other Parts Discussed in Thread: TPS62801, TPS62800
Hi Team,
Could you please let us know about parts number of Aircoil (0.5 mH, DCR = 20 mW)?
User’s Guide
http://www.tij.co.jp/jp/lit/ug/slvu292a/slvu292a.pdf
Kanemaru
  • Hi Kanemaru-san,
    An aircoil inductor is a newer inductor construction technique which is said to eliminate all switching/core losses. Thus, there are just DCR losses and it is more efficient. It is therefore shown as a reference of how high the efficiency can be, with a perfect (AC) inductor.
    What is your Vin, Vout, and Iout required? For example, we have the newer, smaller TPS62801 which generates even higher efficiency than the above with a normal inductor.
  • Hi Chris-san,
    Thank you for the information and your advice.
    I understand that this data of Aircoil is simulation value so not actual data (not actual parts number).
    Is my understanding correct?
    [Your comment]
    Kanemaru
  • Hi Kanemaru-san,
    It is measured data with an air coil inductor. Let me check if I can find further details.
    What do you need in your application?
  • Hi Chris-san,
    Application is consumer device.
    Our customer would like to know the parts number of Aircoil.
    I’d greatly appreciate your verification.
    I’m looking forward to hearing from you.
    Kanemaru
  • Again, we recommend the newer, smaller TPS62800 family for these applications. Why does it not fit?
    The air coil is just a wire with the parameters (L and DCR) shown in the graph. There is no part number.
  • Hi Chris-san,
    Thank you for the information and advice.
    I understand. Thank you very much.
    Kanemaru
