TPS3801: TPS3801K33DCKR
Part Number: TPS3801
Other Parts Discussed in Thread: TPS3103
Dear SIR: (continue before question ,because didn't reply)
Thank for your reply.
But,May I double confirming :
(1) according to your reply:
      Is that meaning as below ?:
       For VDD pin or PFI pin Vref is 0.551V
      TPS3103K33 and TPS3103E16  's VDD pin have "internal resistor divider" therefore base on different sku.(for example: K33 ,E16 ) have different Vth.(K33 ->Vth is 2.941 ,E16 vth is 1.523)
      MR# pin have internal pull up to VDD resistor.
      But, PFI pin without  "internal resistor divider" ,therefore PFI pin need add external resistor divider for met requirement by  Vth =0.551 x (Rtop + Rbottom) / Rbottom  calculator .
      Therefore ,
                        TPS3103K33 vs  MIC2774N-29:
      different I:  TPS3103K33  Vth = 2.941V     MIC2774N-29 Vth = 2.93V
      different II: TPS3103K33  Vref = 0.551V     MIC2774N-29 Vref =0.3V
                       TPS3103E16 vs  MIC2774N-17:
      different I:   TPS3103E16  Vth = 1.523V     MIC2774N-29 Vth = 1.69V
      different II:  TPS3103E16  Vref = 0.551V     MIC2774N-29 Vref =0.3V
     different III: TPS3103 RESET  internal Reset Logic Timer separate with PFI pin   vs   MIC2774N  internal AND  then delay .
     [As you mention before that recommend to wire  together between TPS3103 's RESET pin  PFO pin by external ,But ,the behavior will the same as MIC2774N ? How ? ]
     different IV: TPS3103 Delay Min= 65ms     MIC2774N  Delay Min= 140ms
      The TPS3103 has a 2.941V version (TPS3103K33) but does not have a 1.69V version, the closest is 1.523V (TPS3103E16) or 1.843V (TPS3103H20).
      For the PFI pin, the threshold is 0.551V so you use a resistor divider with
      trigger voltage = 0.551 x (Rtop + Rbottom) / Rbottom
(2) Seams  [A circuit] MIC2774N psec. mention that "It will remain asserted for no less than 140ms after Vin and VDD return above the threshold limits."
     But, TPS3103 spec. mention that Min :65ms Max:195ms.  Is that meaning TPS3103 min: 65ms and can't replace  MIC2774N  Min : 140ms ?
     (Or that TPS3103 min: 65 ms  Max:196 ms  base on different sku (for example: TPS3103K33 ,TPS3103E16 ,....) ,by different strap pin for select ,... that have different  ?)
  • The thresholds and delays vary slightly but the functionality of the devices are the same. I do not think the circuits are configured correctly for the PFI pin. Please use a resistor divider instead of a pull-up resistor only.
    Please let me know if anything is unclear or if you need me to review the final schematic. Thanks!
    -Michael
  • Dear SIR:
    Thanks for your reply.
    But you didn't reply our question directly. Would you reply our question directly ?
          Therefore ,
  • Dear SIR:
    Therefore ,
