Other Parts Discussed in Thread: TPS62421
Hello!
I am a little confused when going through the TPS62420 datasheet and looking at the ability to use easyscale.
Section 8.3.5 DEF_1 Pin Functions - makes it seem that EasyScale will only work with TPS62421 and not the TPS62420.
My customer would like to set the outputs via resistor dividers for the adjustable default output voltage (as stated in Table 5 Device Comparison Table).But the question is can EasyScale be used to move the voltage up/down on out1 and out2?
Reed
