Hi team,
My customer use LMZ10501 but it face some issue that would like to consult with you..The schematic is as below.
There are several assembly board that have the below problem after start up.
Normal:(CH1:EN, CH2:Vout)
Issue1:
It need to take a lot of time (several seconds) to be operating voltage after starting up.
Issue 2:
Output voltage is unnormal after strating up.
We have done some resoldering for the assembly board by hot gun air and the behavior will change into different case with possibility.
May I have your comment and suggestion to prevent the failure case happening possibility ? Thank for your help.
