Other Parts Discussed in Thread: TPS53679,
we encounter similar issue with CSD95490 & TPS53679 and would like to hear how this issue solved?
please share the actions that solved it
Thank you
Doron
Hi Doron,
Please let me know which power stage you are using with TPS53667? Share schematic if possible.
Chasel
as i mentioned, we use CSD95490 & TPS53679 .
Can you share with me how the issue on https://e2e.ti.com/support/power-management/f/196/t/730093 solved? the thread is locked and i hope it would give a hint.
Thank you
Doron
Hi Doron,
Oh, ok, you use the wrong subject and I misunderstood your question.
Regarding the issues you mentioned, our team already involved it for a long time.
Is this the same case?
Thanks.
Chasel
Yes but since i was this similar issue i would like you to share the solution that worked for them
thank you
Doron
Hi Doron,
So is this the same project you're talking about? If yes, I believe the root cause is still under investigation, so I don't have solutions for you at this moment because there is no root cause found out yet.
Chasel
i know but i would like you to share the solution on the https://e2e.ti.com/support/power-management/f/196/t/730093 since it resolved.
thank you
Doron
Hi Doron,
I'm sorry, we are not able to provide any customer proprietary information on E2E if it is not published.
If you need more information, please contact to your local TI representative.
Chasel
