Other Parts Discussed in Thread: UC2524
I have a problem regarding the current limitation schematic found on the SG2524 datasheet, i don't understand the expression of Io(max), we can have this expression only if we have the ground between Rs and R2 ( see the figure below).
On the other hand, we are working on a buck converter in DCM mode, is it possible to integrate the SG2524 current limitation in this mode even if the output voltage depends on the load current in the DCM mode?
Thank you
Kind Regards
N.EN-NASIRY
HW Engineer
