Part Number: UC2843
Hello Team
The customer is using UC2843 in their product. Sometime, the device will work at open load mode. and the current only 10mA. At this mode, the device PWM duty cycle pulse width output will reduce low than minimum of UC2843. And the device sometime will no PWM output. But the output voltage is stable. Please see the following scope. So they want to know if used in this way, is there any risk? And if have risk, what the risk is? thanks.
