Hi team,
My customer wants to ask about power up/down sequence.
They want to use the following power up/down sequence.
Power up:Buck1→Buck2→Buck3
Power down: Buck1, Buck2 and Buck3 simultaneously
To acieve above sequence, they are cosidering to use the following way.
When power up, MODE and EN1,2,3 is set to High.
After powing up, MODE is set to Low.
And then, when powering down, EN1,2,3 is set to Low simultaneously.
Could you check if the above sequence work correctly?
Saito
