Other Parts Discussed in Thread: TPS54292,
Currently I use TPS54291 with 600kHz frequency. If I change to use TPS54292 with 1200kHz, output voltage and power keep original, what should I change?
Maybe the comp parameters should be adjust, but I don't know how to calculate.
the output inductor could keep original design with a lower ripple, but it can worked well, right?
is there any other parameters should be adjust?
thanks.
