The datasheet does not list a recommended maximum voltage for PG pin. Only absolute maximum values are listed. I would like to attach it to a pull-up resistor to a voltage that is higher than the output voltage. I presume it is ok, but it is not written as such in the datasheet. What is the recommended voltage range for PG pin?
