Hi there,
One of the TI guys mentioned that the bode plot simulation for this device to be enabled by the end of April 2019, but still it is not present WEBENCH® Tool.
Do you have any plan / schedule for this?
Thanks & BR,
Ghasem
Hi there,
Thanks & BR,
Ghasem
Hi Ghasem,
I'm checking if this is/was scheduled and, if so, the status. I will give an update here early next week.
We often do not offer bode simulation in WEBENCH for internally compensated devices such is the TPSM84624 module since the supply should be stable so long as the input/output cap and other part selection guidelines in the datasheet are being followed.
Do you have specific concerns? If you share more details on your design and concerns, perhaps I can help address them.
Kris
Hi Kris,
Thank you for your reply.
I'm looking for bode plot for the device. It does not matter if it is not in WEBENCH.
I know the module is table so long as the input/output cap and other part selection guidelines in the datasheet are being followed, but I need to specify stability parameters like PM, GM and crossover frequency.
I don't want to get back to you for every specific design. I would like to have a tool (or whatever) to monitor stability parameters when I'm changing some part of the design.
Ghasem
Hi Ghasem,
I have not seen an email or response from you, so for now I would like to close out this thread.
We do not currently have a model available, but we have measured data for a wide range of operating conditions that we could share if that would help you with your design.
Kris
