Other Parts Discussed in Thread: TPS24770
If we are not using the oring function of the IC how should we connect the following pins:
BGATE
CP
A
C
RVSNM
RVSNP
Should these just be left open/floating?
Hi Steve,
ORing and Hot Swap blocks are set-up independently. Hence, there shouldn't be any issue in leaving the pins related to ORing function floating.
In case you just need the Hotswap functionality of TPS24742 why don't you look at TPS24770.
