Other Parts Discussed in Thread: TIDA-00465, TPS7A4001
Dear all:
The motherboard was normal at first, and it took a while to find the POE interface was abnormal.TPS23861 no output.
Use the voltmeter to touch the positive and negative poles of the power supply pin of the PSE device respectively. The voltage is displayed as 0 volts.It seems that there should be no detection.
Originally thought to be a single board problem, now I found more than one.
Now I want to know what went wrong with the chip and what is the cause of the problem.
Thank!
