Hello Support team,
VOUT DC output accuracy is defined +/-3% as typ.
Does the error value cover Ta=–40~85°C?
What kind of factors are +/-3% contained in?
The variation of Vref, Vfb, Ta range and etc...
Hirokazu
Hello Support team,
Hirokazu
Hi Hirokazu,
According to the datasheet, this accuracy should be for typical conditions, therefore ambient temperature. But I will double check this. Normally, the biggest contributors to the output voltage accuracy should be the reference voltage accuracy (in this case around 1%), and the voltage divider resistors.
Milos
