Other Parts Discussed in Thread: LM3643, LM36011, LM36010, LM3644
Hi Sir,
Does TI have Camera flash LED support hardware control LED current IC?
ILED is 350mA & 1000mA.
Hugo
Hi Hugo,
What's your meaning of "Hardware control"? Usually, our flash LED driver will have an I2C interface, this is very convenient to change the current. For hardware control, maybe you need to change a resistor? What's your detail specifications?
Sean
Hi Hugo,
Sean
Sir,
Hardware control means to use resistor to set LED current. We design a camera flash LED. See attached flash led spec.ELCS14B-NB5060J7J9283910-F4Z_2P.pdf
Hi Sir,
I'm sorry that our flash LED drives are all configured with I2C interface. It is more convenient to use I2C to configure the current and report the error message. Thanks.
Sean
Hi Sir,
There are some different choice for different requirement, for single-channel you can check whether LM36010/LM36011 can meet your requirment. LM3643/LM3644 are dual channels flash LED driver.
Can you share me your detail requirement?
Sean
