I made a prototype following the layout in datasheet/evm with values taken from the LM5155 calculator tool. But on my actual test the output voltage drops at just ~2.5A output. I have attached the schematic, pcb layout and LM5155 spreadsheet calculator. Can someone help me if I may have missed something?
Thank you,
Emman
Thank your for designing with the LM5155. It looks like your circuit hit peak current limit. Can you reduce your sense resistor and see it helps?
Youhao Xi, Applications Engineering
