TPS23881: Sifos test report
Part Number: TPS23881
Hi expert,
Our design will fail when Sifos test.
The fail item is class time and pwron_pwrcap.
Could you help to suggest how we can debug for this issue0083.TPS23881.pdfTPS23881 fail report.docx
  • Hi user4206464,
    The schematic looks good to me.
    Sifos hasn't released the BT test suite with passing and failing report. Are you using Sifos AT test suite?
    If that's the case, you are expected to see some failures as the IEEE802.3bt standard has different spec for detection classification time.
    Regarding your specific issue, what configuration of TPS23881 is set? Can you send me your command to configure PSE registers? 0x12, 0x29 especially. Thanks.
    Penny
