Hi
My customer has question.
When measuring Bode diagram with Split-Rail Power,
Is it correct with the attached wiring?
Regard
T Kishi
We recommend to test loop response from the close loop start and end point. On this circuit, the loop doesn't start from VOPOS-GND but from VOPOS-VONEG. You may move the black probe to VONEG. And looks there's no ripple injection probes which should be between the 50Ohm resistor, please check it.
