Other Parts Discussed in Thread: UC1834
Respected Sir/Madam,
In UC1834-SP, fault alert pin is an open collector for a steady state operation and for any fault condition it would can be pull up with a resistance to get an pulse for any fault. I have already refer the datasheet of UC1834 and Application Note (VERSATILE UC1834 OPTIMIZES LINEAR REGULATOR EFFICIENCY).
If I am want to use this linear regulator for a negative voltage also using fault alert for under voltage protection what would be the possible ways please send a configuration for it ?
I want to know what kind of waveform would appear at fault alert or what kind of connection is to be made for negative voltage for using fault alert pin for protection ?
Thank you,
Meet Pandya
