TPS92640: minimum switching frequency and current limit
Part Number: TPS92640
Other Parts Discussed in Thread: TPS92641
Hi team,
my customer is evaluating our device but from the datasheet it's not clear what's the minimum switching frequency. I read on most of our figures it's showed 500KHz or 1MHz, but my question is can this device work at 50kHz or 100KHz? What is the minimum value?
Also, I see the max output current is 5A but since this is a controller, it should depend on the FET itself right? So how is this 5A maximum calculated? Can it go above 5A, let's say at 6/7A?
If not, could you recommend any other alternative to this device that has same specs but smaller SW frequency and higher output current?
Thank you and best regards,
Adrian
