Other Parts Discussed in Thread: TPS25940
I'm trying to implement the TPS25940EVM-635 as a super capacitor charger. Concerned about that I have few questions.
When I try to use different C_dVdT (C_ss) values I can adjust the voltage rise time. I have noticed that very often the output will be blocked, although the current is well below the limits. The TPS25940 chip seems to be not hot, thus I cant understand why the error is triggered:
If I increase the C_dVdT (C_ss) value slightly (in this particular case to 15uF) it works, although the current is more or less the same.
Could you suggest what the issue could be?
Thanks!
