Other Parts Discussed in Thread: BQ500511A, , BQ51013B
Hi TE2E Community,
I am trying to develop a Wireless Charging Transmitter and designing a charging dock by using bq50002A & bq500511A combination. I followed the application note shared on product page as much as possible. I am using WE760308101103 receiver coil with bq51013B Wireless receiver component and WE760308101111E transmitter coils in my design. When coils are placed in the range of 0mm to 6-7mm, transmitter circuit's green led blinking which means according to LED Mode 1 power transfer. Unfortunately, there is no power transfer detected on the receiver end and the coltage on transmitter coild is barely hitting 1V level. I don't understand what can cause this matter. It cannot be distance because I am also placing both coils on top of each other and it is the same result. I am attaching my Sketch and Bom for my transmitter design. Can somebody give me an opinion where the problem would be causing from ? Thanks.
Partlist exported from R:/KUNDEN/BEIERSDORF/2019 - On Air 2.0/03 Prototyping/03 Data/06 Electronic Development/EAGLE CAD/projects/BDF - On Air 2.0 - Charging PCB/BDF - On Air 2.0 - Charging PCB_ALT2/BDF - On Air 2.0 - Charging PCB_ALT2.sch at 10/03/2020 12:55 Qty Value Device Package Parts Description DATASHEET-URL DESCRIPTION FRES1 HEIGHT IR1 ISAT1 MANUFACTURER_NAME MANUFACTURER_PART_NUMBER MOUSER_PART_NUMBER MOUSER_PRICE-STOCK PART-NUMBER POPULARITY Q1 RDC-MAX1 RDC-TYP1 VALUE 1 PINHD-1X3 1X03 JP2 PIN HEADER 92 1 0.022uF 50v C1608X7R1H223K080AA CAPC1608X80N C12 0603 X7R ceramic capacitor 50V 22nF TDK C1608 C 22nF Ceramic Multilayer Capacitor, 50 V dc, +125C, X7R Dielectric, +/-10% SMD 0603 X7R ceramic capacitor 50V 22nF TDK C1608 C 22nF Ceramic Multilayer Capacitor, 50 V dc, +125C, X7R Dielectric, +/-10% SMD 0.8mm TDK C1608X7R1H223K080AA 810-C1608X7R1H223K https://www.mouser.com/Search/Refine.aspx?Keyword=810-C1608X7R1H223K 1 0.02ohm LVK12R020DER LVK1206_1 R18 Resistor 0.020R 0.5% 0.5W 4 Terminal Ohmite LVK12 Series Metal Alloy Current Sensing Surface Mount Resistor 0.5% 0.5W /-50ppm/degC Resistor 0.020R 0.5% 0.5W 4 Terminal Ohmite LVK12 Series Metal Alloy Current Sensing Surface Mount Resistor 0.5% 0.5W /-50ppm/degC mm Ohmite LVK12R020DER 588-LVK12R020DER https://www.mouser.com/Search/Refine.aspx?Keyword=588-LVK12R020DER 2 0.047uF 10V C1608X7R1H473K080AA CAPC1608X80N C10, C18 TDK C1608 C 47nF Ceramic Multilayer Capacitor, 50 V dc, +125C, X7R Dielectric, +/-10% SMD TDK C1608 C 47nF Ceramic Multilayer Capacitor, 50 V dc, +125C, X7R Dielectric, +/-10% SMD 0.8mm TDK C1608X7R1H473K080AA 810-C1608X7R1H473K https://www.mouser.com/Search/Refine.aspx?Keyword=810-C1608X7R1H473K 4 0.1uF 100V C3216C0G2A104J160AC CAPC3216X180N C14, C16, C17, C19 MLCC - SMD/SMT 1206 0.1uF 100volts C0G +/-5% 1.60mm MLCC - SMD/SMT 1206 0.1uF 100volts C0G +/-5% 1.60mm 1.8mm TDK C3216C0G2A104J160AC 810-C3216C0G2A104J6C https://www.mouser.com/Search/Refine.aspx?Keyword=810-C3216C0G2A104J6C 9 0.1uF 25V 06033C104KAT4A CAPC1608X90N C2, C5, C7, C8, C11, C20, C22, C23, C24 Multilayer Ceramic Capacitors MLCC - SMD/SMT 25volts 0.1uF 10% X7R Multilayer Ceramic Capacitors MLCC - SMD/SMT 25volts 0.1uF 10% X7R 0.9mm AVX 06033C104KAT4A 581-06033C104KAT4A https://www.mouser.com/Search/Refine.aspx?Keyword=581-06033C104KAT4A 2 0.2ohm CRL0805-JW-R200ELF RESC2012X60N R8, R16 Current Sense Resistors - SMD 0.2ohm 5% Current Sense Resistors - SMD 0.2ohm 5% 0.6mm Bourns CRL0805-JW-R200ELF 652-CRL0805JWR200ELF https://www.mouser.com/Search/Refine.aspx?Keyword=652-CRL0805JWR200ELF 1 0.47uF 10V GRM188R71A474KA61D CAPC1608X90N C25 Ceramic SMT capacitor 470nF 10Vdc Murata 0603 GRM 470nF Ceramic Multilayer Capacitor, 10 V dc X7R Dielectric +/-10% Ceramic SMT capacitor 470nF 10Vdc Murata 0603 GRM 470nF Ceramic Multilayer Capacitor, 10 V dc X7R Dielectric +/-10% 0.9mm Murata Electronics GRM188R71A474KA61D 81-GRM188R71A474KA1D https://www.mouser.com/Search/Refine.aspx?Keyword=81-GRM188R71A474KA1D 1 1000pF 50V CGA3E2C0G1H102J080AD CAPC1608X90N C9 Multilayer Ceramic Capacitors MLCC - SMD/SMT 0603 50V 1000pF C0G No Solder-Glue Only Multilayer Ceramic Capacitors MLCC - SMD/SMT 0603 50V 1000pF C0G No Solder-Glue Only 0.9mm TDK CGA3E2C0G1H102J080AD 810-C1608C0G1H102JEP https://www.mouser.com/Search/Refine.aspx?Keyword=810-C1608C0G1H102JEP 3 100kOhm CRCW0402100KFKED RESC1005X40N R15, R21, R22 CRCW0402 Resistor T/R 0.063W,1%,100K Vishay CRCW Series Thick Film Surface Mount Resistor 0402 Case 100k +/-1% 0.063W +/-100ppm/C CRCW0402 Resistor T/R 0.063W,1%,100K Vishay CRCW Series Thick Film Surface Mount Resistor 0402 Case 100k +/-1% 0.063W +/-100ppm/C 0.4mm Vishay CRCW0402100KFKED 71-CRCW0402-100K-E3 https://www.mouser.com/Search/Refine.aspx?Keyword=71-CRCW0402-100K-E3 2 100v, 0.2A MMDL914-TP SOD2512X115N D2, D3 Diodes - General Purpose, Power, Switching 100V 200mA 4pF Diodes - General Purpose, Power, Switching 100V 200mA 4pF 1.15mm Micro Commercial Components (MCC) MMDL914-TP 833-MMDL914 https://www.mouser.com/Search/Refine.aspx?Keyword=833-MMDL914 6 10kOhm CRCW040210K0FKED RESC1005X40N R7, R12, R20, R24, R25, R26 CRCW0402 Resistor T/R 0.063W,1%,10K Vishay CRCW Series Thick Film Surface Mount Resistor 0402 Case 10k +/-1% 0.063W +/-100ppm/C CRCW0402 Resistor T/R 0.063W,1%,10K Vishay CRCW Series Thick Film Surface Mount Resistor 0402 Case 10k +/-1% 0.063W +/-100ppm/C 0.4mm Vishay CRCW040210K0FKED 71-CRCW0402-10K-E3 https://www.mouser.com/Search/Refine.aspx?Keyword=71-CRCW0402-10K-E3 1 10kOhm MCS0402PD1002DE500 RESC1005X37N R14 Thin Film Resistors - SMD .200W 10Kohms .5% 0402 25ppm Hi Power Thin Film Resistors - SMD .200W 10Kohms .5% 0402 25ppm Hi Power 0.37mm Vishay MCS0402PD1002DE500 594-MCS0402PD1002DP5 https://www.mouser.com/Search/Refine.aspx?Keyword=594-MCS0402PD1002DP5 1 113kOhm ERJ-2RKF1133X RESC1005X40N R1 Thick Film Resistors - SMD 0402 113Kohms 1% AEC-Q200 Thick Film Resistors - SMD 0402 113Kohms 1% AEC-Q200 0.4mm Panasonic ERJ-2RKF1133X 667-ERJ-2RKF1133X https://www.mouser.com/Search/Refine.aspx?Keyword=667-ERJ-2RKF1133X 4 1kOhm CRCW04021K00FKED RESC1005X40N R4, R9, R17, R19 CRCW0402 Resistor T/R 0.063W,1%,1K Vishay CRCW Series Thick Film Surface Mount Resistor 0402 Case 1kOhm /-1% 0.063W /-100ppm/degC CRCW0402 Resistor T/R 0.063W,1%,1K Vishay CRCW Series Thick Film Surface Mount Resistor 0402 Case 1kOhm /-1% 0.063W /-100ppm/degC 0.4mm Vishay CRCW04021K00FKED 71-CRCW0402-1.0K-E3 https://www.mouser.com/Search/Refine.aspx?Keyword=71-CRCW0402-1.0K-E3 1 2.2uF 10V GRM188R71A225KE15D CAPC1608X90N C3 Ceramic SMT capacitor 2.2uF 10Vdc Murata 0603 GRM 2.2??F Ceramic Multilayer Capacitor, 10 V dc, +125??C, X7R Dielectric, ??10% Ceramic SMT capacitor 2.2uF 10Vdc Murata 0603 GRM 2.2??F Ceramic Multilayer Capacitor, 10 V dc, +125??C, X7R Dielectric, ??10% 0.9mm Murata Electronics GRM188R71A225KE15D 81-GRM188R71A225KE15 https://www.mouser.com/Search/Refine.aspx?Keyword=81-GRM188R71A225KE15 1 2.2uF 16V EMK107BJ225KA-T CAPC1608X50N C21 Multilayer Ceramic Capacitors MLCC - SMD/SMT 2.2uF 16V X5R +/-10% 0603 Gen Purp Multilayer Ceramic Capacitors MLCC - SMD/SMT 2.2uF 16V X5R +/-10% 0603 Gen Purp 0.5mm TAIYO YUDEN EMK107BJ225KA-T 963-EMK107BJ225KA-T https://www.mouser.com/Search/Refine.aspx?Keyword=963-EMK107BJ225KA-T 1 200kOhm CRCW0402200KFKED RESC1005X40N R23 CRCW0402 Resistor T/R 0.063W,1%,200K Vishay CRCW Series Thick Film Surface Mount Resistor 402 Case 200k?? ??1% 0.063W ??100ppm/??C CRCW0402 Resistor T/R 0.063W,1%,200K Vishay CRCW Series Thick Film Surface Mount Resistor 402 Case 200k?? ??1% 0.063W ??100ppm/??C 0.4mm Vishay CRCW0402200KFKED 71-CRCW0402-200K-E3 https://www.mouser.com/Search/Refine.aspx?Keyword=71-CRCW0402-200K-E3 1 2200pF 50V C0603C222K5RACAUTO CAPC1608X87N C13 KEMET C0603C222K5RACAUTO 2.2nF MLCC 50V dc +/-10% Tolerance SMD KEMET C0603C222K5RACAUTO 2.2nF MLCC 50V dc +/-10% Tolerance SMD 0.87mm Kemet C0603C222K5RACAUTO 80-C0603C222K5RAUTO https://www.mouser.com/Search/Refine.aspx?Keyword=80-C0603C222K5RAUTO 3 22uF 25V GRM21BR61E226ME44K CAPC2012X145N C1, C4, C6 Multilayer Ceramic Capacitors MLCC - SMD/SMT Multilayer Ceramic Capacitors MLCC - SMD/SMT 1.45mm Murata Electronics GRM21BR61E226ME44K 81-GRM21BR61E226ME4K https://www.mouser.com/Search/Refine.aspx?Keyword=81-GRM21BR61E226ME4K 1 24.9kOhm CRCW040224K9FKED RESC1005X40N R3 Vishay CRCW Series Thick Film Surface Mount Resistor 0402 Case 24.9k +/-1% 0.063W +/-100ppm/C Vishay CRCW Series Thick Film Surface Mount Resistor 0402 Case 24.9k +/-1% 0.063W +/-100ppm/C 0.4mm Vishay CRCW040224K9FKED 71-CRCW0402-24.9K-E3 https://www.mouser.com/Search/Refine.aspx?Keyword=71-CRCW0402-24.9K-E3 1 2700pF 50V C1608C0G1H272J080AA CAPC1608X80N C15 TDK - C1608C0G1H272J080AA - CERAMIC CAPACITOR 2700PF 50V, C0G, 5%, 0603, FULL REEL TDK - C1608C0G1H272J080AA - CERAMIC CAPACITOR 2700PF 50V, C0G, 5%, 0603, FULL REEL 0.8mm TDK C1608C0G1H272J080AA 810-C1608C0G1H272J https://www.mouser.com/Search/Refine.aspx?Keyword=810-C1608C0G1H272J 1 2ohm CRCW04022R00FKED RESC1005X40N R11 Vishay CRCW Series Thick Film Resistor 0402 Case 2 1% 0.063W +/-100ppm/K Vishay CRCW Series Thick Film Resistor 0402 Case 2 1% 0.063W +/-100ppm/K 0.4mm Vishay CRCW04022R00FKED 71-CRCW0402-2-E3 https://www.mouser.com/Search/Refine.aspx?Keyword=71-CRCW0402-2-E3 1 499kOhm CRCW0402499KFKED RESC1005X40N R10 RESISTOR, 0402 499K Ohms +/-1% 0.063W RESISTOR, 0402 499K Ohms +/-1% 0.063W 0.4mm Vishay CRCW0402499KFKED 71-CRCW0402-499K-E3 https://www.mouser.com/Search/Refine.aspx?Keyword=71-CRCW0402-499K-E3 1 5V MOUNT-PAD-ROUND2.8 2,8-PAD H4 MOUNTING PAD, round 6 1 6.3uH WE-WPCC_TX_1COIL_760308100111 WE-WPCC_TX_760308100111 WE760308100111 WE-WPCC Wireless Power Transfer Transmitter Coil https://katalog.we-online.com/pbs/datasheet/760308100111.pdf 24MHz 6A 10A 760308100111 120 48mOhm 40mOhm 6.3uH 1 69.8kOhm CRCW040269K8FKED RESC1005X40N R6 Vishay CRCW Series Thick Film Resistor 0402 Case 69.8k 1% 0.063W +/-100ppm/K Vishay CRCW Series Thick Film Resistor 0402 Case 69.8k 1% 0.063W +/-100ppm/K 0.4mm Vishay CRCW040269K8FKED 71-CRCW0402-69.8K-E3 https://www.mouser.com/Search/Refine.aspx?Keyword=71-CRCW0402-69.8K-E3 1 7.5kOhm ERA-2AEB752X RESC1005X40N R2 Panasonic ERA Series Thin Film Surface Mount Resistor 0402 Case 7.5k +/-0.1% 63mW +/-25ppm/C Panasonic ERA Series Thin Film Surface Mount Resistor 0402 Case 7.5k +/-0.1% 63mW +/-25ppm/C 0.4mm Panasonic ERA-2AEB752X 667-ERA-2AEB752X https://www.mouser.com/Search/Refine.aspx?Keyword=667-ERA-2AEB752X 1 76.8kOhm ERA-2AEB7682X RESC1005X40N R13 Thin Film Resistors - SMD 0402 76.8Kohm .1% AEC-Q200 Thin Film Resistors - SMD 0402 76.8Kohm .1% AEC-Q200 0.4mm Panasonic ERA-2AEB7682X 667-ERA-2AEB7682X https://www.mouser.com/Search/Refine.aspx?Keyword=667-ERA-2AEB7682X 1 80.6kOhm CRCW040280K6FKED RESC1005X40N R5 Vishay CRCW Series Thick Film Resistor 0402 Case 80.6k 1% 0.063W +/-100ppm/K Vishay CRCW Series Thick Film Resistor 0402 Case 80.6k 1% 0.063W +/-100ppm/K 0.4mm Vishay CRCW040280K6FKED 71-CRCW0402-80.6K-E3 https://www.mouser.com/Search/Refine.aspx?Keyword=71-CRCW0402-80.6K-E3 1 BQ50002ARHBR BQ50002ARHBR QFN50P500X500X100-33N IC1 Low-Cost 5-V Wireless Power Transmitter AFE WPC V 1.2 A11 Transmitter Low-Cost 5-V Wireless Power Transmitter AFE WPC V 1.2 A11 Transmitter 1mm Texas Instruments BQ50002ARHBR 595-BQ50002ARHBR https://www.mouser.com/Search/Refine.aspx?Keyword=595-BQ50002ARHBR 1 BQ500511ARHAR BQ500511ARHAR QFN50P600X600X100-41N IC2 Wireless Charging ICs Wireless Power Transmitter Controller 40-VQFN -40 to 85 Wireless Charging ICs Wireless Power Transmitter Controller 40-VQFN -40 to 85 1mm Texas Instruments BQ500511ARHAR 595-BQ500511ARHAR https://www.mouser.com/Search/Refine.aspx?Keyword=595-BQ500511ARHAR 1 GND MOUNT-PAD-SQUARE2.8 2,8-PAD-SQUARE H3 MOUNTING PAD, square 3 2 Green 150060GS75000 LEDC1608X80N D1, D6 Wurth Elektronik WL-SMCW 520 nm Green LED, 1608 (0603) Clear SMD package Wurth Elektronik WL-SMCW 520 nm Green LED, 1608 (0603) Clear SMD package 0.8mm Wurth Elektronik 150060GS75000 710-150060GS75000 https://www.mouser.com/Search/Refine.aspx?Keyword=710-150060GS75000 1 NTCG163JF103FT1 NTCG163JF103FT1 THRMC1608X90N RT1 NTC Thermistors THERMISTOR, NTC 10K OHM, 1%, 0603 NTC Thermistors THERMISTOR, NTC 10K OHM, 1%, 0603 0.9mm TDK NTCG163JF103FT1 810-NTCG163JF103FT1 https://www.mouser.com/Search/Refine.aspx?Keyword=810-NTCG163JF103FT1 1 Red 150060SS75000 LEDC1608X80N D5 LED,Wurth Elektronik,150060SS75000 Wurth Elektronik 150060SS75000, WL-SMCW Series Red LED, 630 nm, 1608 (0603) Clear, Rectangle Lens SMD Package LED,Wurth Elektronik,150060SS75000 Wurth Elektronik 150060SS75000, WL-SMCW Series Red LED, 630 nm, 1608 (0603) Clear, Rectangle Lens SMD Package 0.8mm Wurth Elektronik 150060SS75000 710-150060SS75000 https://www.mouser.com/Search/Refine.aspx?Keyword=710-150060SS75000 1 Yellow 150060YS75000 LEDC1608X80N D4 LED,Wurth Elektronik,150060YS75000 Wurth Elektronik 150060YS75000, WL-SMCW Series Yellow LED, 590 nm, 1608 (0603) Clear, Rectangle Lens SMD Package LED,Wurth Elektronik,150060YS75000 Wurth Elektronik 150060YS75000, WL-SMCW Series Yellow LED, 590 nm, 1608 (0603) Clear, Rectangle Lens SMD Package 0.8mm Wurth Elektronik 150060YS75000 710-150060YS75000 https://www.mouser.com/Search/Refine.aspx?Keyword=710-150060YS75000
