Other Parts Discussed in Thread: OPA2210,
Dear SME, my circuit input is +-12V, the output is +-5v used for powering amplifier OPA2210. +-12V go through 1amp fuse and supplied to TPS7A3901.
however, when I powered on +-12V, the 12V voltage after the fuse go to only about 2.1V, the -12V voltage after fuse go to about 11V. The power is about +-12V.
And I measured the resistor of the fuse, it seems Ok. But there is large volate drop on the fuse.
Do you anyone have any idea about this issue, this is the first time I use TPS7A39. I have no idea what's wrong with it. I checked the circuit and It's really confusing.
Is there any short circuit?
Appreciate for the response.
thank you.
David
