Hi team,
Could you provide the equation for frequency configuration with RT, CT ?
And are there any application report to know more detail to design circuit with UC3825 ?
Thank you and best regards,
Michiaki
Hi team,
Michiaki
Hi Michiaki,
I didn't find a equation for the frequency of UC3825, you can design the frequency according the figure of "Timing Resistance vs Frequency " in page 6 of datasheet. It is more accurate than the equation.
I only found one UC3825 application note for your reference, http://www.ti.com/lit/an/slua053/slua053.pdf but I think it is more like a power note.
If you want to verify the calculation and design, it is a good solution to use a simulation module which is available online.
https://www.ti.com/product/UC3825/toolssoftware
Teng
Hi Teng,
Does customer need cut and try on TINA and design without equation ?
Michiaki
Hi Michiaki,
Yes, customer can select the RT and CT according the figure of "Timing Resistance vs Frequency " in page 6 of datasheet. And I recommend to use a simulation to rectify the result if they want.
Teng
Hi Teng,
Could you kindly advise what difference is between UC3825 and UC3825A/B ?
We can find the more detail in the datasheet of UC3825A/B.
Should we recommend UC3825A/B instead of UC3825?
Michiaki
Hi Michiaki,
In most applications, the UC3825A/B devices are enhanced drop-in replacements for UC3825a/B high speed PWMs. We can recommend UC3825A/B to customer instead of UC3825.
The differences can be easily found in the attached document. And also datasheet.
http://www.ti.com/lit/an/slua125/slua125.pdf
Teng
