Please let me know is it mandatory to connect SET pin. What will happen if it is floating?
Amar.
Amar.
Hi Amar,
It is mandatory to connect the SET pin on this device to select the threshold level. The device requires an accuracy band to be set to be able to trip at the correct voltage level. If the pin is floating, it will not be able to correctly distinguish between the desired levels on the device.
Abhinav.
