Other Parts Discussed in Thread: BQ2031, BQ25703A, BQ25703, BQ24650
HII
i want to use your BQ24450 for lead acid battery charger my maximum charging voltage is 6 v and i want to charge 4 v lead acid battery .is it possible ?
and another question what is the minimum voltage i need to supply to the BQ24450 in order to charge 6v lead acid battery .
and the same question applies for the bq2031 ??
do you have a recommendation for charger ic for lead acid batteries , my max charging voltage 6 v with current 2.15 A
I NEET TO CHARGE 4V LEAD ACID and 6v lead acid ?
