Other Parts Discussed in Thread: TPS2121, BQ24170
I have been testing the BQ24170EVM. The user guide says that the Vin should be minimum 1V above the regulated charging voltage for the converter to operate properly. I have tested it for 1S and 2S charging application and found the following results:
- For 1S the converter only starts working when the voltage is around 7V, so 2.8V above the 4.2V charging voltage, but it actually continues working below 7V when it has already started operation.
- For 2S found similar behaviour, converter started working at aroun 10V for the 8.4V charging regulated voltage.
The question is: could you please provide accurate information about the minimum Vin at rising edge (minimum Vin for the converter to start) and falling edge (voltage below which the converter stops operating once it had started); for 1S, 2S and 3S charging?
Thank you,
