At present, it is found that the IC is easy to be damaged during testing and needs help analysis.
IC usually damaged for pins HS and HB, they will have low impedance occurs during the measurement of high-side and low-side MOSFETs (use 5 * 6 MOSFETs and lift them for testing).
How can I prevent this damage?
The test location as the green area
Best Regards
Rock Shao
Hello Rock,
I am sorry, but please upload a higher resolution schematic. I cannot read the values you are using.
What do you mean with lifting the MOSFETs for testing?
Which voltages do you have on VIN and VOUT, what is your load current?
Please check the voltage on the pins HB and HS when you do not lift anything.
Hi Brigitte,
Let me ask another way. Have you encountered the low impedance of HB and HS in your experience? Is this IC suitable for adding a resistor for the R-C filter to the charge pump capacitor between HB and HS to prevent noise (Blue or red resistor in the picture)? Can it be prevented by add D5?
Or are there other ways (except that the charge pump is close to the IC) to prevent this damage?
Best regards
Hello Rock,
I personally do not know of any issue like this with this part. For solving the issue, the information and measurements that I asked for would be very helpful:
Please check the voltage on the pins HB and HS in normal operation.
