Other Parts Discussed in Thread: TPS54360
I have designed a PCB that would take a 60V input and output a voltage from 5V to 50V depending on a digital potentiometer IC.
This is my 3rd/4th iteration of the board and it would be great if I could get someone to look over the PCB and Schematic as I have doubts on the compensation circuit.
How will the compensation values work since the output is a range? I used the Webbench and for every different output voltage the compensation circuit changes.
I do not want to post the schematic and PCB layout here, so it would be awesome if I can email it to the person that helps me out!
Kind Regards
Sagar
