Hi Team,
We've received an inquiry from a customer if it is possible to connect a P-MOSFET to the output of LP5012 to drive an LED at higher current?
Does he need to add a pull up resistor to keep the MOSFET off when the OUT pins of LP5012 is not sinking current? He prefers to use 1Mohm.
The customer wants to know if it is important to set the resistor for iREF if the pull-up resistor is 1M ohm?
Danilo
