What cost-effective/ most-efficient solution do you suggest for an application that needs more than a 48 channel LED driver.
Hi Daviel,
Could you help to introduce more background, is it used into panel backlighting or other thing? And for the LED structure, does it need control all LEDs individually, or cascading some and paralleling some?
Here is an AN that you could refer that using matrix structure to drive a large number of LEDs individually.
TLC59581 - AN - Build a High-Density, High Refresh Rate, Multiplexing Panel With the TLC59581.pdf
