TPS56C230: How to control EN pin from VCC pin
Part Number: TPS56C230
Dear TI Team
Our customer is considering using the voltage output from the Vcc pin to control the EN pin on the TPS56C230.
(A 100kΩ resistor is connected between VCC and EN)
However, if you check Figure.17 of the data sheet, the voltage of VCC rises after EN rises.
Therefore, I think that the EN pin cannot be controlled by the output voltage of the VCC pin.
Is this perception correct?
Y.Ottey
