The spreadsheet in the original post was very helpful. I didn't catch the mistake in the equations in the data sheet. When I look at the example design there are components on it that are not included in the datasheet description. Such as the series capacitor (470p) resistor (10) from SW2 to ground and the C6 / C8 capcitors across the compensation components. For C6 / C8 I am not sure how they are calculated. Will either of these affect the C1 / C2 values in the resistive divider?
I am also a little confused about what Cout is. I have Cout capcitors right at the output of the supply but then I also have bulk capacitors near the loads. Do I need to take the bulk capacitors into account when calculating the compensation.
Thanks you,
Jennifer
