Hello team,
I have a question about the TPS386000 WDO output behavior at power up.
Does /WDO just follow VCC?
Or, /WDO keep low until the VCC exceeds +0.9V (power-up reset voltage), and then go to high-Z?
Itoh
Hello team,
Itoh
Hi Itoh-san,
/WDO is at a high-impedance state when VCC < 900mV. Since the /WDO in the TPS386000 is an open drain output that can be tied to a resistor to VCC, /WDO will follow VCC. Once VCC > 900mV, the /RESET pin can toggle and the WDI timer begins.
Ben
