Hello Team,
can you confirm the following options of using the output drivers?
They both look good, while the last point is a "misuse" it is reasonable to save space and cost.
1. It should be possible to operate the LEDs mixed from a 3V3 and a 5V0 supply. Red=> 3V3, Blue=> 5V0 ?
2. I've two RGB LEDs connected. The third is unused. Is it possible to use the other outputs as digital out
with a 10k pull-up to 3V3?
Thanks for the feedback,
SunSet
