Hi team
I want to step down 5V (Vin) to 3.3V (Vout) using TLV742P(TLV74233PDQNR).
I use 5V as the power supply (Vdd) and 3.3V as the pull-up voltage (Vsignal) for another IC.
If 5V is interrupted, Vsignal> Vdd due to the residual voltage.
The rating of this IC is Vsignal> Vdd + 0.3V, so I need to insert a diode between the Vout-Vin pins of the TLV742P.
Can you disclose to me the data of the forward voltage of the body diode inserted in the package of TLV742P?
For other measures, I have placed a pull-down resistor near Vout.
As a result, the time it takes for Vout to discharge is designed to be about 0.16 μs.
