For LP8869C-Q1, FAULT Pin is connected to 5v pullup instead of connecting to VDDIO. While measuring the voltage at Fault pin it is showing only 4.6V instead of 5V. We have used 10k Resister value for pullup, What is the Reason for this voltage drop?
Hi Sir,
I suggest to measure the 5V rail and find the other possible leakage path of fault pin. Also check the mcu fault read back IO. Share your related schematic to clarify your circuit.
Hi Sir,
I will close this thread temporarily since you don't have feedback for me. You can keep ask questions if you have any update.
