Dear TI member,
We are using TI/TPS68470YFFR and have below question
1.
(1)Could HCLK_A pin of TI/TPS68470YFFR output 19.2M Hz?
(2)Would you mind to let us know how to set it?
2.TI/TPS68470YFFR is implement for rear camera application.
TI/TPS68470YFFR has two I2C ports. One connects to rear camera and the other one connects to CPU(Host) I2C port
We are using Pin C6(GPIO5) be GPO pin to be Camera_Indication_LED control. When rear camera operation, Pin C6(GPIO5) output high in order to enabled Camera_Indication_LED.
(1)Does it set by I2C of CPU(Host) side or ?
Thank you.
