TPS53317: switching frequency tolerance at Vout=0.6V
Part Number: TPS53317
Please see below schematic. The MODE setting is PWM and fsw is 1MHz.
My customer measured fsw as below:
Vin=5V
Vout=0.6V
Could you please comment whether the fsw result is acceptable?
And I also need the fsw tolerance@Vin=5V and Vout=0.6V
  • Hi Jim,
    We don't have tolerance with 5V input, 0.6V output. The tolerance of 5V input, 1.05V output is about +/-10%.
    With 0.6V output, the switching frequency will be slightly higher than 1.05V output. The tolerance in your test results looks ok.
    Weidong
