My customer is ongoing to design following datasheet recommendation.
Problem statement:
1 Customer cannot place less than 1608 cap size.
2 Available / selectable cap value under 1608size is only 0.1uF
3 Need to locate to closest point near VIN-GND line but length might be 4-5mm distance
4 Another alternative option is to utilize VIA then locate VIN CAP on the another side of PCB pattern.
Customer would like to use both 0.1uf of 1005size and 2012 size 10uF with palalell.
Would you please kindly advice this condition suggested layout proposal ?
Hironori Yoshimura
