Hello team,
Due to a stock problem, my customer is considering LM60430-Q1 for their project. Their project uses the Raspberry Pi zero (1GHz) as their edge compute. They will use the LM60430-Q1 as a 24 to 5 V DC-DC converter. They will generate PWM signals at 400 Hz, kHz and kHz. They also do some sensing and data capture using the Raspberry Pi Zero W, then push that data to the cloud. Your thoughts on using this chip. What are the pros and cons?
Renan
