TPS61096A: Vosns vs VB
Part Number: TPS61096A
Dears  currently used  TPS61096A  for variable output application through switching dedicated resister divider using  external -  mosfet ,
so couly you help check below parameter may related with my application
1. Vosns - output voltage sense pin  + FB  , monitor from my oscilloscope ,  it seems that 10us duration and FB ping should be sample during this period .
 could you support us the detail logic of Vosns  on time combine with FB sampling .
2. below is my sch, and prepare to use mosfet configure the ouput ,  but the mosfet intenal c influnce the procedure of FB sampling which lead to some mis-voltage output,
could you give us some golden adivise, really looking forward to your reply.
nicky
