Hi TI expert
In TPS40056 controller datasheet page 12 Figure 4, The graphic shows VIN-VSW looks difficult to understand.
When high side MOSFET is ON, VIN-VSW is supposed to be low, but it is high in this graphic. VIN-VSW=Vds of high side MOSFET.
Can you please elaborate it?
The second issue is I want to know the OC fault counter. Will it be tripped 2nd tier OC only when there are 7 successive OC event? Or the 7 cycle OC event is a sum data? Let's give an instance here, if there are 5 successive OC event detected already, then the 6th cycle OC fault disappeared, will the counter stay 5 or 4 or reset to 0?
