Other Parts Discussed in Thread: PMP8973, UCC2897A
Is it possible to trim the output voltage to 3.3V instead of 5V?
Thank you for your question.
To change the output voltage several components would need to be changed in the design such as the transformer, FB resistor divider circuitry, sense resistor, etc.
However we have a 3.3V / 50W design, PMP8973, that I recommend you take a look at.
This design uses the UCC2897A DC-DC and can be paired with the TPS2372-3 to achieve the power and output voltage desired.
Please let me know if you have any other questions. Thanks!
Brett Colteaux
PoE Product Marketing Engineer
