I am using BQ2002T board http://www.ti.com/lit/ug/sluu007b/sluu007b.pdf using 6 cells. Depending on the batteries the charger can sometime get stuck in this loop:
Vbat <2 volts then full charge
Vbat>2 volts then trickle, but when it goes to trickle the voltage drops below 2volts so it goes back to full charge, then back to trickle than back to full charge. This can last sometimes an hour. How can this be improved so the charger stays in full charge for several minutes after it passes 2V?
