Hi team,
Customer want to change the feedback resistance from R1=2.2M and R2=160k to R1=4.3M and R2=330k respectively, keeping same voltage =18V.
What's the concern they should consider or is it acceptable in design or not?
Regards, Naoki Yada
Hi team,
Regards, Naoki Yada
higher dividing resistor may lead to poor output voltage accuracy. Higher current flow through the dividing resistor gives out the higher accuracy. But if their output voltage accuracy is not tight, they can do so.
