Hi e2e,
Recently, a customer had an inquiry about measuring bode plots at both DIFFO pin and Vout+.
He was wondering if there is any difference between these 2 pins when measuring the bode plots?
Questions:
1. Is there any difference between these 2 points? I noticed for DIFFO pin, the signal communicates within IC and for Vout+, the signal go through external parts.
2. If different, which point should I measure in order to obtain the most accurate result?
Joe
